Creating electronic lock
tompzone
Has thanked: 4 times
Post by tompzone »
hi i am trying to create a electronic lock, using a keypad, using 3 numbers (170 by the way), but i am not able to "memorize" each pulse and it's value, and i dont know how to make the comparison so it can accept or reject the password, (i am using 2 leds as outputs)
Re: Creating electronic lock
Here is a four digit version:
http://www.matrixmultimedia.com/mmforum ... 253#p19233
It can be adapted for 3 digits, instead of four.
Have a go at altering it, as that's the best way to learn.
Someone will help you when you get stuck.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Sean also did an article on an electronic door lock with a MIAC. It may be of some use to you.
http://www.matrixmultimedia.com/article.php?a=53
tompzone
Post by tompzone »
thanks alot!
SkeeterB11
Post by SkeeterB11 »
I created an electronic lock that uses 3 digits. It's got a simple bit where it reads the code stored in the EEPROM of the uC and compares it to the one you just entered. If the code is correct, you get the door unlocked , a green LED illuminated, and a prompt to enter quickly before it returns to its previous state. It's also got a remote open function where it unlocks if the pushbutton is depressed. It also clears the variables in order to increase the security of the lock.
KeylessLock.fcf
My Keyless Lock.
(42.52 KiB) Downloaded 426 times
This is the way the world ends,
Not with a Bang,
But With a Belch
BURRRRRRPPPPPP
