Hello all,
I'm somewhat in a jam.
I have a multiplication to do however it only works partially:
T2 = 11 * (C6 +24) * (200 - TEMP) * (200 - TEMP) / 2^20
I have made a C Code box with the following lines:
long t2;
t2 = 11 * (FCV_C6 + 24); This parts is alwas 561
t2 = t2 * (200-FCV_TEMP); TEMP can be anywhere from -150 to 199
t2 = t2 >> 20;
FCV_T2 = t2;
The problem is that the calculation works untill TEMP = -55. As soon as the TEMP is lower as -55 the T2 goes to 0
My question is; Can a PIC18F4685 actally handly such a calculation?
If it does, what am I doing wrong?
Henk
Large multiplication
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: Large multiplication
I would imagine that you are using a BYTE to store one of your variables, the maximum value a byte can hold is 255. Try changing them to integers. If this isnt the case, attach your fcf file to the post and ill take a look at it.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
You could try this instead:
long t2;
t2 = t2 * (long)(200-FCV_TEMP);
t2 = t2 >> 20;
FCV_T2 = t2;-
henker
- Has thanked: 7 times
- Been thanked: 2 times
OK, I got it working.
This is the solution:
t2 = t2 * ((long) 200-FCV_TEMP);
t2 = t2 >> 20;
FCV_T2 = t2;
Thanks for bringing me in the right direction.
Henk
t2 = t2 >> 20;
FCV_T2 = t2;
Henk
- Steve
Hi Henk,
Glad you got it working. Instead of "long", you can probably get away with "int" or "signed int" (this may save a small amount of processing and variable space if that's important to you).
