support for floor(float)
billduck
Has thanked: 23 times
Been thanked: 16 times
Post by billduck »
I have written a program, in which I use use the floor(float) function in a decision branch. It runs in simulation mode, as I want. But it will not compile. The message is
" MoveAZ_6_10Works_RS232.c:(.text+0x17a): undefined reference to `float32_to_int32_round_down' " ,with no further detail. I might add, that I prototyped the subroutine, using an 6 pin connection LCD, without regard to what pins to which it is connected. I re-wrote the program for a serial LCD, like I have on the microcontroller, and got the same results.
Thanks in advance.
MoveAZ_6_10WorksB.fcf_avr
Program for 6 connection LCD
(11 KiB) Downloaded 282 times
billduck
Re: support for floor(float)
Post by billduck »
Attached is a much simpler and short program, showing the same message, as it does not compile:"Floor.c:(.text+0xf4): undefined reference to `float32_to_int32_round_down'".
Thanks.
Floor.fcf_avr
(5 KiB) Downloaded 276 times
Please can you try copying the attached file into your "Flowcode AVR v4/FCD" folder and this should then allow you to compile the function correctly.
internals.c
(27 KiB) Downloaded 261 times
billduck
Post by billduck »
Thanks. I was working on a solution, where I cast a float as an integer. Seemed to get around the floor anomily.
