2 timers
talal
2 timers
Post by talal »
hello everybody
how to make 2 timers which can be run at the same time and can be changed
best regards
Re: 2 timers
Which version of Flowcode are you using? You should simply be able to enable and change the interrupts including timers as you require them. Have you looked at the examples in the examples download. These contain good starting points for using interrupts and timers.
talal
Re: 2 timers
Post by talal »
thanks for your kindly reply
i am using v4
really i could not understand how the interrupts work So, can you just help me to writ simple program with two timers which run at the same time then i can do some changes to learn more
best regards
Re: 2 timers
Please can you join the v4 forum topic and then post in the correct section of the forums, I have moved your post accordingly.
http://www.matrixmultimedia.com/mmforum ... =29&t=6524
Here is a very quick example using two timers.
Timers.fcf
(6 KiB) Downloaded 214 times
