Int2float
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Int2float
Post by Jan Lichtenbelt »
I get lost. I have the byte Count and the float Sin3. To convert Count from byte to float I use the euqation:
sin3 = int2float(Count).
In the simulation this works correct, but in the PIC877A the byte Count=203 will be converted into the float Sin3 = 200.0000.
See test2 file at the main macro next to remark "Here the Count(byte) will be converted into Sin3 (float)"
What do I wrong?
Jan Lichtenbelt
PS. In the meanwhile I find out that any mathematical equation on this place gives wrong results.
Test2.fcf
(9.5 KiB) Downloaded 236 times
Re: Int2float
Hello Jan,
In your program you are enabling timer 0 but disabling timer 1. Could this be the source of the problem?
Jan Lichtenbelt
Re: Int2float
Hi Ben,
You are right.Because timer 1 is going on, the variable Count will change with time, also after the int2float equation.
Kind regards
Jan
