I can't receive Bytes from MCP9800
HjH
Been thanked: 2 times
Post by HjH »
I can't receive Bytes from MCP9800. This is my first I2C project.
Have anybody a smal example that can receive Bytes from MCP9800.
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: I can't receive Bytes from MCP9800
Post by Spanish_dude »
Could you upload/attach your flowcode file and .c file ?
HjH
Post by HjH »
here is my code
Temp_MCP9800_Modified.fcf
(12.46 KiB) Downloaded 315 times
I think I can see a potential problem with the code.
In the I2C_Read_MCP9800 macros you are passing the same address for both the read and write operations.
The least significant bit should be set for one of these transmit byte functions. I forget which one but the datasheet should detail this.
