Simulation running well but not in the MIAC
icare34
Flowcode V4 User
Has thanked: 5 times
Post by icare34 »
I have a problem with the program test2.fcf
The simulation is running well on my computer ( 22 is display), but when I transfer the the program in the MIAC, it display 0.0000
If I put :
toto = 10.0
instead of :
toto = 10.0 + 12.0
it running well on PC and MIAC (display : 10.00...)
Where is the problem ?
  • Program problem ?
  • Compilation problem ?
  • Transfert problem ?
  • Miac Problem ?
How can I solve it ?
Best regards
Didier
test2.fcf
Program with problem
(5.5 KiB) Downloaded 270 times
Re: Simulation running well but not in the MIAC
When using the BoostC compiler toolchain, you need to use the special floating-point functions (fp_add, etc) to perform arithmetic on floating-point numbers.
I suggest you use integers where possible: "toto = 10 + 12" should work fine.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
May I also add that if you are using Flowcode V4 could you please post any questions which include Flowcode V4 programs into the relevant V4 forums.
Instructions on how to do this are available here: http://www.matrixmultimedia.com/support ... f=29&t=602
icare34
Flowcode V4 User
Post by icare34 »
Thanks a lot :D
With :
toto = fadd(10.0 , 12.0)
everything is OK.
Could you please transfer my question to V4 forums ? I can't do by myself.
