Hey guys,
Im trying to implement the analogue to digital conversion but nothings happening.It wont display anything on the screen.The LCD just shows the blocks when i power it up.After trying to get this to work i tried a simple program just to display some string on the LCD but even this didnt work..Any ideas as to what my problems could be?
LCD display
Re: LCD display
What are you using to create the code? If its Flowcode then please post your question in the relevant Flowcode topic.
You need to ensure your clock speed is as defined in the project options window and you will also need to assign correct configuration settings to match your hardware.
Re: LCD display
Hey ..i posted it in the flowcode section sorry for that..i changed the project options to my clock speed and also made the changes in the chip configure window but still nothing
