Error in the SPI definition
HjH
Been thanked: 2 times
Post by HjH »
Hallo,
the controler is a 24FJ128GA010 on the explorer board.
I will write in a SPI EEPROM
The programm compiled with following errors:
Explorer_Test1.c: In function 'FCD_SPI_Legacy0_SPI_Init':
Explorer_Test1.c:990: error: 'SPI1CON' undeclared (first use in this function)
Explorer_Test1.c:990: error: (Each undeclared identifier is reported only once
Explorer_Test1.c:990: error: for each function it appears in.)
Explorer_Test1.c:991: error: 'SPI1CONbits' undeclared (first use in this function)
can you help me
Explorer_Test1 with error.fcf_pic16
(16.53 KiB) Downloaded 294 times
Re: Error in the SPI definition
In your Project options -> Supplementary code window please add the following lines of code.
#define SPI1CON SPI1CON1
#define SPI1CONbits SPI1CON1bits
This should then let you compile correctly.
