Dear All,
I'm a new member in matrix multimedia user forums.
I've just started using flowcode V3. While compilation it says internals.c file is missing in FCD directory. However, the directory contains internals.h file. Is it possible to obtain the internals.c file for flowcode V3 or is it possible to change the compiler setting so that it looks for internals.h file instead of internals.c?
Please advise.
Flying_Bird
Internals.c file Needed
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Re: Internals.c file Needed
Have you tried uninstalling and re install from your original CD, (your registration info should still be stored on the system) ,then use help check for updates.
Internals.c is a critical part of the system, and is included in the installation exe file.
Otherwise if this doesn't work you should post in the Flowcde V2&V3 section of the forum for support on this topic.
Flying_Bird
