Problem with float...
PIC_Man
Flowcode V4 User
Post by PIC_Man »
i have created a c-file like the tutorial flowcode 4 , a simple operation with floating point numbers( variable type float). there are no error during compilation, but when used the simple operation like +, - , * , /, the result was wrong and the lcd shows -1.///////.
the lcd in flowcode-simulation shows 0.000000.
the same problem is in the macro. only the functions fadd(),fmul() a.s.o. works correct. i have no idea about the reason.can you help me??
DavidA
Has thanked: 58 times
Been thanked: 258 times
Re: Problem with float...
Post by DavidA »
Please post in the Flowcode V4 forums as you state you use Flowcode V4.
Help on how to do this is available here:
http://www.matrixmultimedia.com/support ... f=29&t=602
DavidA
Post by DavidA »
Thank you for registering as a V4 user!
Please post your Flowcode file for us to look at for you.
PIC_Man
Flowcode V4 User
Post by PIC_Man »
Please see the file in the attachment....
Testumgebung_PIC16XXXX_C.fcf
(6 KiB) Downloaded 226 times
DavidA
Post by DavidA »
You have written the calculation in a c-code block rather than a calculation block, I have attacvhed a working version for you to look at.
(6 KiB) Downloaded 281 times
