rs232 baud rate problem
greentech
Flowcode V4 User
Has thanked: 10 times
Been thanked: 2 times
Post by greentech »
Hi there,
I am experiencing a strange problem with rs232 component baud rates. I have successfully communicated with the pc, but there is a strange problem going on, when i choose 19200 baud rate i have to downgrade the baud rate to 9600 in hyper terminal, and suppose i have chosen 9600 baud rate then to communicate with pc ill have to choose 4800 baud rate in hyper terminal. whats going on, i cant really understand.
flow code 19200 = 9600 hyper terminal
flowcode 9600 = 4800 hyper terminal.
why cant i select same baud rates at both sides?
Re: rs232 baud rate problem
Sounds like your hardware is not running at the speed you think it is. Have you tried the 1 second flasher test on your hardware to see if this is running correctly at 1 second.
You do this by creating a infinite loop at the start of your program.
loop
output 255 to a port
delay 1 second
output 0 to a port
delay 1 second
end loop
If the hardware is not flashing at a rate of 1 second on the hardware then either your clock speed or configuration settings in Flowcode are incorrect for your hardware setup.
greentech
Flowcode V4 User
Post by greentech »
yes benj i have tried that, but it seems to be ok. i matched the blinking speed with stop watch on.
greentech
Flowcode V4 User
Post by greentech »
HI THERE,
I have checked, and rechecked the program using led flasher program, the program seems to be working fine as i am using matrix eboard eb006-007 xtal set to 19.66xx, i can send the chars without a problem but while receiving things change. Could this be coz im receiving transmission from a gsm module? any idea?????? :?: :?: :?: :?: :?: :?: :?:
greentech
Flowcode V4 User
Post by greentech »
ne 1 there?
Ben's away for a week, sorry.
greentech
Flowcode V4 User
Post by greentech »
oh ic, is everything alright with him?
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Hes fine hes just on a break :)
greentech
Flowcode V4 User
Rs232 baud rate problem
Post by greentech »
:)K David. May i know if there's gsm component gonna be out for ds pic?
