pcb artwork
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
rashid1
pcb artwork
Post by rashid1 »
wouldn't it be nice if matrixmultimedia could intergrate some kind of pcb layout design after flowcode is designed
Re: pcb artwork
We did have plans for doing something similar to this but I think we are not going to have time to develop and squeeze it into version 5. Maybe something for version 6? All of the E-block datasheet contain schematics of the boards so you should be able to build up custom circuits fairly easily.
rashid1
flowcode 5 example
Post by rashid1 »
this file example 1.single servo motor control is not compiling
errors
I think It does not like the targeted pic 16f88
any ideas why
Re: pcb artwork
Hi rashid1,
Servo component will only work with target devices that has got at least built in 2CCP channels.
16F88 only has one, hence will not compile.
Also Servo component will only work with professional version and not the free or Student/Home version.
If you're asking about any component to do with professional version, then you must first register for the correct part of forum
You are more likely to receive a reply if posting in the correct part of the forums.
For V4 is this link:
http://www.matrixmultimedia.com/mmforum ... =29&t=8762
For V5 its this link:
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
