Good day all.
I'm using a chip that has 2 USARTs. Using the zigbee componet, I would like to know how to set the component
to use USART 2.
Ondra
Zigbee TX, RX Port From 1 to USART 2
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Zigbee TX, RX Port From 1 to USART 2
You'll need to customise the C code behind the Zigbee component. Looking at the code, I think the only code you'll need to customise are the following:
- [Defines]
[Initialization]
Receive_Char
Send_Char
Thanks Dave.
I was hoping it could be done.
To tell you the truth I'm a flowcode programmer.
I need lots of help when It comes to working in C.
If you find the time could you assist with the changes.
Thanks in advance.
Thanks in advance.
Boy, that was fast.
You will be missed. Enjoy.
Anybody else out there can help, I'd much appreciate it.
Ondra
Ondra
Hello Ondra,
Ok here is how its done,
Init Section.
Replace with
Replacing "MX_ZIG_TRIS" with your actual tris eg trisa and replacing MX_UART_TX, MX_UART_RX with the actual UART pin numbers eg 0 and 1.
Send Char.
replace with
Finally Receive Char Function.
Replace with
I would suggest you change one function at a time and then do a test compilation to ensure you are not introducing errors to the code and so you know which bit is causing problems should you run into any.
Init Section.
clear_bit (MX_ZIG_TRIS, MX_UART_TX); // TX pin is an output
set_bit (MX_ZIG_TRIS, MX_UART_RX); // RX pin is an input
txsta = MX_ZIG_TXSTA; // 8-bit, async, low speed, off
spbrg = MX_ZIG_SPBRG; // set the baud rate 9600
rcsta = 0; // 8-bit, disabled
st_bit(rcsta, SPEN); // turn on serial interfaceCode: Select all
txsta2 = MX_ZIG_TXSTA; // 8-bit, async, low speed, off
spbrg2 = MX_ZIG_SPBRG; // set the baud rate 9600
rcsta2 = 0; // 8-bit, disabled
st_bit(rcsta2, SPEN); // turn on serial interfaceSend Char.
st_bit(txsta, TXEN);
while (ts_bit(pir1, TXIF) == 0);
#if MX_ZIG_HWFC == 1
while ((MX_ZIG_PORT & (1 << MX_ZIG_CTSP) ) != 0); //wait until CTS is low
#endif
txreg = nChar; Code: Select all
st_bit(txsta2, TXEN);
while (ts_bit(pir3, TX2IF) == 0);
#endif
txreg2 = nChar; Finally Receive Char Function.
while (rxStatus == 0)
if (ts_bit(pir1, RCIF) != 0)
//received a Char
rxStatus = 2;
else
if (bWaitForever == 0)
//don't wait forever, so do timeout thing...
if (nTimeout == 0)
rxStatus = 1;
else
//decrement timeout
delay1--;
if (delay1 == 0)
nTimeout--;
if (rxStatus == 2)
if (ts_bit(rcsta, FERR) != 0)
dummy = rcreg; //need to read the rcreg to clear FERR
else
if (ts_bit(rcsta, OERR) != 0)
//need to read the rcreg to clear error
cr_bit(rcsta, CREN);
st_bit(rcsta, CREN);
else
retVal = rcreg; //no error, so rx byte is valid
} } }Code: Select all
if (ts_bit(pir3, RC2IF) != 0)
//received a Char
rxStatus = 2;
else
if (nTimeout == 0)
rxStatus = 1;
else
//decrement timeout
delay1--;
if (delay1 == 0)
nTimeout--;
if (rxStatus == 2)
if (ts_bit(rcsta2, FERR) != 0)
dummy = rcreg2; //need to read the rcreg to clear FERR
else
if (ts_bit(rcsta2, OERR) != 0)
cr_bit(rcsta2, CREN);
st_bit(rcsta2, CREN);
else
retVal = rcreg2; //no error, so rx byte is valid
} } }Regards Ben Rowland - MatrixTSL
