HI, Guys,
Looking for a bit of help and a point in the right direction.
I am looking at building some equipment that requires me to give 8 PWM output signals.
I have chosen to use the PIC18F4431 as the has the number of PWM outputs I need, how ever when looking at flow code it will only allow me to us 2.
Is there a way to change this, or how do I go about implementing to other PWM outputs in to my software.
I will be using the ADC inputs to control the duty cycle form 0 to 100%.
Any help with the above will be very appreciated.
Tristan
PIC18F4431 PWM
Re: PIC18F4431 PWM
Hi Tristan,
Take a look at all of this thread, as it may help?
http://www.matrixmultimedia.com/mmforum ... 19&start=0
trisb
- Flowcode V4 User
- Has thanked: 6 times
Re: PIC18F4431 PWM
Hi, Martin,
Thanks for the reply, I did come across this one and it looks great. you spent some time on this.
I have a question for you.
In the flow code you have a calculation as follows:
Steps = ((ADC2*40)/(40/10))
ccpxcon = (Steps AND 3)*16+12
ccprxl = Steps>>2
Am i right in saying ccpxcon & ccprxl, should be for example ccp5con & ccpr5l if I am using the pwm 5 on pin 37 (RB5) on the PIC18F4431 chip.
And the C Code would be:
ccpr5l = FCV_CCPR5L;
ccp5con = FCV_CCP5CON ;
am I understanding this right???
Tristan
ccprxl = Steps>>2
Tristan
Re: PIC18F4431 PWM
I just had a look at the the data sheet for PIC18F4431, and I don't think its possible the way that's described in the link I posted.
I should have looked at the data sheet before I replied. Sorry about that.
trisb
- Flowcode V4 User
Re: PIC18F4431 PWM
No Problem.
I have been looking at other chips and based on how I think your example shows, an i right in saying that If the chip has multiple CCP pins it should work.
I am now looking to use a 18F66K22. and will be dropping to 7 PWM outputs. I will use a second chip for the 8th PWM,
Re: PIC18F4431 PWM
Hi Tristan
Luckily this is easy to find the ideal chips.
Go to:
http://www.microchip.com/maps/microcontroller.aspx
and just unselect 16 and 32 bits so that just 8 bit is selected.
Then select 3 (or any min number of channels required) for 'from' and all for 'to' column. of 'Input Capture'
You will then get a list of microcontrollers you can use.
Best to create a flowchart with desired target device, to make sure its compatible with Flowcode (just compile to hex) before ordering chip.
I used a 16F737, but that's getting a bit old in the tooth now.
Yes your correct. Its only the chips with multiple CCP channels that will work with the posted method.trisb wrote: I have been looking at other chips and based on how I think your example shows, an i right in saying that If the chip has multiple CCP pins it should work.
Go to:
