Hi, All
Can somebody help me to figure out on how to make something like this.
To Go out of a menu screen I would like to make the user hold a button for several seconds before turning back the menu will exit.
If the user presses this button quick the program will return to the top of the menu, this menu will not exit.
I hope somebody can figure this out.
I have tryed it but no succes.
Regards Jordy Kleian
Push Button Hold (1s) Little Help
- Jordy101091
- Has thanked: 25 times
- Been thanked: 188 times
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
Re: Push Button Hold (1s) Little Help
You just need to check your input, if it's high for let's say 200ms then it's a short pulse and if it's still on after 700ms it's a long pulse.
Hope this helps.
Nicolas
EDIT : You just need to change the two if-statements to increase or decrease the time the user needs to push the button. I did it for 200ms and 700ms but you can change that pretty easily.
char counter, pulse;
counter = 0;
while ((portb & 0x01) == 1) // check portb pin 0
delay_ms(20); // delay 20ms
counter++; // increase counter
if (counter <= 10) // 200ms = 20ms * 10
pulse = 0; // short pulse
else if (counter >= 35) // 700ms = 20ms * 35
pulse = 1; // long pulse
Nicolas
