Using the DAC on the EB013 along with a ECIO28P.
The DAC only uses SCK, SD0 and DAC EN, but not SDI. Can I use the SDI(RB0) as an independent i/o line, or does it get tied up with the SPI Legacy routines?
SDI on EB013 SPI board
Re: SDI on EB013 SPI board
I'm afraid I think it gets tied up with the SPI peripheral which takes overriding control of the pin.
If you needed the extra I/O pin then creating a Flowcode macro that will bit bang the SPI signal to the DAC should be fairly straight forward.
