Hallo
ich will mit einem 24F16KA102 eine I2C EEPROM beschreiben. Leider bekomme ich beim kompilieren folgende Fehlermeldungen.
ExtEEPROM.c: In function 'FCD_I2C_Master0_MI2C_Init':
ExtEEPROM.c:676: error: 'I2CCONbits' undeclared (first use in this function)
ExtEEPROM.c:676: error: (Each undeclared identifier is reported only once
ExtEEPROM.c:676: error: for each function it appears in.)
ExtEEPROM.c:686: error: 'I2CBRG' undeclared (first use in this function)
ExtEEPROM.c: In function 'FCD_I2C_Master0_MI2C_Start':
ExtEEPROM.c:772: error: 'I2CCONbits' undeclared (first use in this function)
ExtEEPROM.c: In function 'FCD_I2C_Master0_MI2C_Restart':
ExtEEPROM.c:810: error: 'I2CCONbits' undeclared (first use in this function)
ExtEEPROM.c: In function 'FCD_I2C_Master0_MI2C_Stop':
ExtEEPROM.c:854: error: 'I2CCONbits' undeclared (first use in this function)
ExtEEPROM.c: In function 'FCD_I2C_Master0_MI2C_Transmit_Byte':
ExtEEPROM.c:899: error: 'I2CTRN' undeclared (first use in this function)
ExtEEPROM.c:900: error: 'I2CSTATbits' undeclared (first use in this function)
ExtEEPROM.c: In function 'FCD_I2C_Master0_MI2C_Receive_Byte':
ExtEEPROM.c:973: error: 'I2CCONbits' undeclared (first use in this function)
ExtEEPROM.c:980: error: 'I2CRCV' undeclared (first use in this function)
was mache ich falsch.
mit freundlichen Grüßen
HjH
I2C Error
Re: I2C Error
Hallo HJH,
Es scheint, dass Microchip hat beschlossen, alle I2C Register auf diese Familie von Geräten umzubenennen. Ich habe Ihre zusätzlichen Code-Fenster geändert werden, um damit das Programm korrekt kompiliert.
Hello HJH,
It seems that Microchip has decided to rename all the I2C registers on this family of devices. I have modified your supplementary code window to allow the program to compile correctly.
Hello HJH,
- ExtEEPROM.fcf_pic16
- (13.61 KiB) Downloaded 389 times
