I want two comparators with internal reference voltage for e.g. PIC16F877A
http://ww1.microchip.com/downloads/en/D ... 39582b.pdf
The CVRON Control register gives me the wanted reference voltage (see chapter 13) and the comparator register CMCON (CIS=CM3) tells me which 2 inputs I can use (=0 for RA3 and RA2 or =1 RA0 and RA1). The output of the comparators can be read from CMCON bit 6 and 7 (CM6 and CM7).
Now I want to use these outputs in the software only and preventing them to come on the outputs RA4 and RA5.
Now my question: How do I prevent that the the comparator-outputs comes on RA4 and RA5? Just by setting trisa?
But if I set RA4 and RA5 as output, can I use RA4 and RA5 as ouptput for other reasaons? Or will RA4 and RA5 as output always comparator outputs?
With kind regards
Jan Lichtenbelt
Comparators
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
Re: Comparators
Hi Jan,
I read the datasheet (chapter 13) and they don't seem to say that when using the comparator you can't use RA4 and RA5 as 'normal' I/O.
I'd suggest you to leave RA4 and RA5 as inputs (with trisa) and when you need to output something on those I/O, turn them back to output, but also, disabling the comparator.
Once you're done, set RA4 and RA5 back to input and enable the comparator.
Nicolas
Nicolas
- Jan Lichtenbelt
Re: Comparators
Dear Nicolas
The problem is that I want RA4 and RA5 to use as outputs for other purposes and at the same time I need the 2 comparators (form which I read outputs from CMCON register).
Kind regrads
Jan
Kind regrads
Jan
Sean
- Has thanked: 6 times
- Been thanked: 44 times
Re: Comparators
The selection of RA4 and 5 as comparator outputs is based on the CM2:0 mode bits.
The modes listed as 'with Outputs' in the Comparator I/O Operating Modes table (Figure 12-1 in my copy of the 877 data sheet) control the I/O. The remaining modes leave the I/O unaffected.
The multiplexers that controls the I/O can be seen in the schematics for RA4 and 5 in the I/O Ports section of the data sheet. This is more informative than the comparator table.
Spanish_dude
Re: Comparators
I haven't checked that chapter yesterday, but it seems that setting CM2:0 to 010b will allow you tu use the comparator without outputs.
Thanks Sean
Nicolas
Thanks Sean
Nicolas
