compiling problem
nuwan5213
Has thanked: 24 times
Been thanked: 4 times
compiling problem
Post by nuwan5213 »
hi,
im getting this message when compiling flowchart to hex.
test.c(1843): error: missing semicolon
test.c(1843): error: missing right paren
test.c(1571): error: failure
failure
Return code = 1
FINISHED
my flow chart is heare.
please help.
nuwan
test.fcf
(14 KiB) Downloaded 238 times
Electronics for better world.
Re: compiling problem
Hi nuwan,
I have highlighted the box causing the error.
(17.69 KiB) Downloaded 1325 times
You have placed a string in a calculation box with no number within the brackets. So that will though up an error.
A couple of tips
1) In stead of just having the default title for components, e.g Calculation. Place a unique number after.
so you could have Calculation 1, Calculation 2 for the next etc.
2) Take a look at this if you get any more errors, it may help you to track them down.
http://www.matrixmultimedia.com/mmforum ... =26&t=6936
Scroll down to
C) General use of Flowcode.
That will explain about tracking cause missing semicolon errors.
If all components have a unique reference, then when given the offending line number, you can look at corresponding line number in your C code, and trace problem as you will see the a unique reference within the area causing problem.
What did you believe the highlighted box would do?
nuwan5213
Post by nuwan5213 »
Hi.
martin thanks.
i corrected my flowchart.
regards,
nuwan.
