input and output on same port pin
barryw
Post by barryw »
Hi, I'm trying to use the same port pin as a digital in and out. however as soon as I set the port to give an output it resets back to an input on the next instruction, do I need to use soms ASM code to reset the pin to an output for a duration , then use ASM again to reset to an input?
if so can you please give me a sample to follow or point me to the right place in the forums.
BarryW
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: input and output on same port pin
Post by Spanish_dude »
Could you attach your .fcf and .c files ?
You don't need ASM to do that, using the input and output icons in flowcode should do the trick.
Nicolas
