C source code option
allpicproject
Flowcode V4 User
Has thanked: 17 times
Post by allpicproject »
Hi all,
My suggestion is to have a menu ( radio button/check box / etc ) to set which C format to be generated when push button of 'generate C sourcecode'.
What I'm doing now, doing some project for student/friend, whenever they want C source code, I need to trim the source code in Hitech C code ( they compile using Hitech C ) as I dont want them to confuse with the many pages code.
If we have choice of C format to generate then we can learn C language more clear ( I use flowcode to learn C in PIC ). By doing so, I won't confuse with sourcebootC , formula C etc. Also we have small C file.
Sorry for my bad english, hope you will get my point.
Allpic
Re: C source code option
Thanks for the great suggestion.
We have implemented something similar to this for the upcoming V5 release. The C code generated will be much cleaner because the processor- (and compiler-) specific code will be hidden within what we call the CAL (code abstraction layer). I hope this will satisfy your need.
allpicproject
Flowcode V4 User
Yes, that's my intention. (Please also make for the include file ie internal.h n definition.h ).
I'm volunteer to test it in ver5.x (if there is opportunity ).
Rgds
Allpic
