16F1824 EEPROM issue.
If you use EEPROM with 16F1824, then flowchart will fail to compile.
The cause I have traced to some missing definitions in 16F1824.fcd file.
Attached is an updated file which has not been approved by Matrix, so please use at your own risk.
File should be placed in \Matrix Multimedia\Flowcode V4\FCD folder.
For settings to take effect, you must first close Flowcode if still running.
16F1824.fcd
(10.11 KiB) Downloaded 506 times
Re: 16F1824 EEPROM issue.
Thanks Martin,
I have been through and found the cause of this problem and fixed it for the next update release, many thanks for the spot.
Your welcome Ben,
Would you mind confirming the changes I made are OK and officially people can use the posted file?
EEPROM did appear to work OK, but that’s no guarantee file alterations are 100% correct.
