Lots of Bugs with 24FJ256GA110
Mathy
Has thanked: 30 times
Been thanked: 33 times
Post by Mathy »
I have many problems with the 24FJ256GA110 I did not on other references (eg 24FJ256DA210).
I think one of the problems is related to the configuration module fuses "PPP". It doesn't support this chip as well when I import the hex file, PICkit 2 software tells me that all fuses are not configured.
This problem causes a malfunction since it is impossible to use the external oscillator. The chip switches to the internal oscillator at 4 Mhz.
The burning also becomes very long when it is done directly by Flowcode.
The other problem is that I can not use the SPI modules. neither the first nor the second. Nothing comes out of the component pin.
Can you see what you can do? I completly blocked, my board absolutly needs two SPI connection.
Thank you for your help.
Mathy
Re: Lots of Bugs with 24FJ256GA110
Post by Mathy »
here, you can see the message given by pickit 2 software when I import the generated hex file.
Mathy
Post by Mathy »
Help :( :( :(
