EB069-RESET
yannr
Has thanked: 9 times
EB069-RESET
Post by yannr »
I'd like to make a FACTORY RESET on a EB069 CARD (WIFI card).
I'have tried to modify the input port 1 and 3 (triggger and reset)
but I don't know exactly WHAT to put on this port...
and for how many time?
thanks,
yann
INSA 1er cycle GCP projects with or without eblocks:
https://www.youtube.com/user/yricotti
Re: EB069-RESET
Hello Yann,
If you select the WLAN component on the panel and then click custom code, then select the initialise function and click edit. A factory restore can be completed by un-commenting the following section of code.
//Uncomment this line if module locks up and no longer gets through Init
//delay_s(30);										//Perform Factory Reset
Once you have restored the factory settings go back into the custom code feature and restore the init function to default.
yannr
Re: EB069-RESET
Post by yannr »
thank you for the answer.
I've un-commented the section of code.
but my WIFI card is still unreachable.
have you an exemple of code tu run with in order to reset the card?
yann
Re: EB069-RESET
Hello Yann,
It could be your pin connections at fault. Can you refer to the wireless LAN E-block datasheet and ensure all your connections are correct. Holding the reset line high for 30 seconds was working 100% reliably here to unlock the WLAN module and allow it to start operating again. According to Wiznet this problem does not exist so I am glad someone else has come across it.
If you cant get it working then let me know and I will see what else we can try. Do you know what you were doing before the module locked up.
yannr
Re: EB069-RESET
Post by yannr »
Hi Benj,
the problem: I've put a password on the WIFI card and I have made a mistake so ...
I can't connect any more with It... It's why I'd like to make a factory reset.
I try to give you more information:
first of all my electronic assembly:
photo of my electronic assembly
secondly one of the numerous program I try with
reset6.fcf
program to use with my electronic assembly
(4 KiB) Downloaded 387 times
practically, I try to press more than 30 seconds on the button sw3 of port D in order to have
reset to 1 on the bit 3 of the port C where I have my WIFI card.
I can control this with the led card and I have also done this without the led CARD directly.
thank you for the time,
yann
benp
Has thanked: 3 times
Been thanked: 41 times
Re: EB069-RESET problem-solution
Post by benp »
Here is the solution:
There are errors in the EB069 wlan e-block user manual.
On following description, there are 6 connections on the J2, J3, J4 connectors:
- Table: Signal Connections using the Patch System p4
- Appendix 1: Circuit diagram p7
But on the physical true EB069 and the pictures in the user manual, there are only 5 connections.
The reset pin is not on the patch A or B or C. The RST pin have a direct connection from the patch to the MAX3002.
So the only way to connect the reset pin is to wire the patch between J6 and J5. For example, between "RST" and "3" (printings on the PCB) if you want to respect the table p4 for patch A or patch B.
A quicker method to factory reset is to connect a wire in RST from the patch and just touch +V for more than 3s. If the new SSID is WLANAP, you did it.
The new parameters can be found in trhe wiz610wi user manual:
IP: 192.168.1.254
Subnet: 255.255.255.0
DHCP server
http://www.youtube.com/user/INSAgcp
Re: EB069-RESET
Early versions of the board had the 6th pin missing from the jumpers as we were deciding if it was required for operation or not. The final version of the board we are now shipping has a 6-way jumper and patches through the reset signal.
yannr
Re: EB069-RESET
Post by yannr »
thank you to benp and benj.
my problem is over. I've reset my wifi card.
have a nice day,
yann
