led matrix
nuwan5213
Has thanked: 24 times
Been thanked: 4 times
led matrix
Post by nuwan5213 »
hi all,
anybody have idea how to run led matrix with flowcode?.simply i want to make message display.
can anybody give simple example program.?
thanks .
nuwan :?
Electronics for better world.
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: led matrix
Post by Spanish_dude »
What I did is an array of bytes where each bit represents a single LED.
Let's say you have an 8x8 LED Matrix then I'd do an array of 8 bytes.
I use this array as a "displaybuffer".
Then I turn each row one after the other and send each byte to the display.
I usually use a for loop.
Let's say you connected PORTB (8 pins) and PORTC (8 pins) from PIC 'X'.
PORTB is used to send the data: 1 is on, 0 is off
PORTC selects the row which you want to enable: 0 is on, 1 is off.
// main
char displaybuffer[8] = {0}:
char row = 0;
// display an 'X'
displaybuffer[0] = 0b10000001;
displaybuffer[1] = 0b01000010;
displaybuffer[2] = 0b00100100;
displaybuffer[3] = 0b00011000;
displaybuffer[4] = 0b00011000;
displaybuffer[5] = 0b00100100;
displaybuffer[6] = 0b01000010;
displaybuffer[7] = 0b10000001;
//main loop
for (row = 0; row < 8; row++)
    PORTC = ~(1 << row); // shift and invert
    PORTB = displaybuffer[row]; // output data
//end loop
You could use an interrupt to display your buffer on the LED Matrix (actually I recommend this).
This way, you can do stuff in the main, like changing the displaybuffer, and each time the interrupt is triggered you write on the LED Matrix.
Nicolas
nuwan5213
Re: led matrix
Post by nuwan5213 »
hi nicolas.
Thanks.
Now i know the concept.can we do that clean flowcode without c code.because im not much c player.
Can we mask some outputs as a data of port a.then give address from other port.is it possible.
Or givin data same way and scan address by using onther oscillator like 4017 possible.
Thanks.
Nuwan.
Sent from my mobile device.
Spanish_dude
Re: led matrix
A 4017 is a 10 decade counter if I remember well ...
If so then you'll need to sync your data with the frequency of which the 4017 counts.
This will save you a whole port (assuming you're using an 8x8 LED Matrix).
Re: led matrix
There is a good project for creating a 8x8 LED matrix using 1 x 8-bit port and 2 x control lines available from here.
http://adrianus.3x.ro/electronic/zws_co ... lboard.htm
The project is good and works as I have tried it personally but my antivirus is warning about the favicon from this site so take care when visiting.
nuwan5213
Re: led matrix
Post by nuwan5213 »
hi ben,
thanks.
have you got any written flowcode for led matrix.
nuwan. 8)
STibor
Has thanked: 116 times
Been thanked: 113 times
Re: led matrix
Post by STibor »
Not tested. 4*4 led matrix multiplex.
Good luck!
matrix mpx.fcf
(14.72 KiB) Downloaded 455 times
nuwan5213
Re: led matrix
Post by nuwan5213 »
hi simphy
Any advise to me? For matrix....
Im new to led projects.
Nuwan.
nuwan5213
Re: led matrix
Post by nuwan5213 »
hi all, ben,
have youn got any written program for led matrix.
why dont you matrix team dont add the component of that,
nuwan..... :|
