<^< 7-Segment Decoder Driver | Course Index | 1. Output >^>
Flowcourse lesson plan
From this point on, to do all the labs, you will need:
- Flowcode 4
- E-Blocks Multiprogrammer
- E-Blocks LED board
- E-Blocks Switch board
- E-Blocks LCD board
Part | Title | Description |
A | Step-by-step 1-8 | Take time to work through the step-by-step section from the first lesson up till the lesson on the 'Goto' or Connection Point icon. |
B | Help file | Take time to get to know your way around the help file inside Flowcode. You will have to be able to use the help file whenever you get stuck. |
From this point on, to do all the exercises, you will need:
- Flowcode 4
- E-Blocks Keypad board
- E-Blocks Sensor board
- E-Blocks 7-seg. board
- E-Blocks Patch board
- LM35 or LM34 temp sensor
K | Step-by-step 9-12 | Take time to work through the Step-by-step section from 7-segment display onwards. |
Part
| Title
| Estimated time
Q
| Project 1
R
| Project 2
<^< 7-Segment Decoder Driver | Course index | 1. Output >^>
