Flowcode 8 crash
maharadga
Has thanked: 17 times
Been thanked: 12 times
Flowcode 8 crash
Post by maharadga »
When I want start FC8, it crash when logo appear and close. In Task Manager stay process Flowcode 32 Bit with 0 Byte memory used.
Before this I use it normally and work with Circular buffer and Console. Suddenly, a window called for Windows to shut down appeared.
This was 2 times.
I reinstall 2 times Flowcode 8, but after some time the same problem is appear again.
Anybody have some idea?
Re: Flowcode 8 crash
Tiny's post here should help without having to re-install.
viewtopic.php?f=78&t=21531&start=25
Let us know how you get on.
maharadga
Post by maharadga »
Hello, Benj.
I doed it like You say and FC8 started normally without uninstall and install it.
We'll see how long, though. If I have to do it every time ... this is not a normal program, if the reason is in it.
added later:
FC8 crash again. I run reg-file, who I saved before and problem solved, I sure temporary.
I read this post :
http://www.flowcode.co.uk/mmforums/viewt ... 78&t=21531
My problem is the same.
This is big bug in Flowcode 8. Need to be resolved. I can't work.
When FC8 crash, it not save changes.
patrick schoon
Has thanked: 7 times
Been thanked: 13 times
Post by patrick schoon »
I have the same issue.
As wel on Win7 as Win10.
Just while working the software freeses and disapears.
After restart of the pc and starting FC8 it popup and disapears the same time. Dead software
A reinstall did not work..
Then deleted the FC8 in regedit and all words again. Settings gone..
Hope this wil help the developers.
Please see Steve's posts on this topic starting from this one.
http://www.flowcode.co.uk/mmforums/viewt ... =25#p98745
If anyone is getting this problem on a regular basis. i.e. over the course of several days or ongoing then please do let us know. We use a lot of the internal Windows libraries such as VC++ and this is now all managed via Windows update and may be being updated behind the scenes. I had this problem several times over the course of a week months ago but since then it has never happened again.
Out of interest are you behind some sort of Windows server with self managed updates?
Flowcode just crashed causing windows to shut down.
My system reported by msinfo32:
Microsoft Windows 10 Home 64bit
Version 10.0.18363 Build 18363
Flowcode would not load until deleted registry.
I have saved the offending registry.
Would it help if I uploaded it?
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
No need to upload the registry as I know what's preventing Flowcode from running. The reason for the initial crash, however, remains a mystery.
I did release (via PM) a special build of Flowcode v8 at the end of Jan to people who were experiencing the problem. This tackles some of the potential causes for the crash, and should allow Flowcode to restart without needing the registry fix. I will discuss here about releasing this as an official patch.
If you or anyone else wants to try this special build then please let me know.
Steve.
Thanks Steve :)
Frank607
Has thanked: 29 times
Been thanked: 15 times
Post by Frank607 »
I have the same problem. FlowCode crashes and Windows shuts down. The crash from FlowCode comes randomly if I click something in FlowCode. This I have since I bought V8.
Now I can’t even start FlowCode. The “start” logo is been seen and then it disappears and FlowCode won’t start anymore.
I have just downloaded and reinstalled FlowCode but it doesn’t fix the problem.
Windows 10 Enterprise 64Bit
Frank
UPDATE:
I have again uninstalled FlowCode. The REG key (FlowcodeV8) was still there. I have deleted the REG key and reinstalled FlowCode.
HKEY_CURRENT_USER\Software\MatrixTSL\FlowcodeV8\WindowPlacement
For now FlowCode will start. I keep you updated.
Post by Steve »
Thanks, Frank.
We should have a patch for V8 out later this week.
Steve.
Frank607
Post by Frank607 »
Hi Steve,
Thanks. It is still working without any crashes or Windows shutdown. I have opened FC8 many times now.
So it could be a registry problem. Because when I delete the FlowcodeV8 key it is still working after a reinstall. But this is up to you :-)
Frank
Hi Frank,
Should not need to reinstall.
Make sure Flowcode is not running then delete registry.
Frank607
Post by Frank607 »
FYI.
The above error suddenly came back. After deleting the reg key Flkowcode8 FC starts again.
anzacinexile
Has thanked: 16 times
Been thanked: 18 times
Post by anzacinexile »
Did a patch go out Steve?
My V8 would regularly and reliably crash needing the registry hack to bring it back if I simply hit the "remove unused variables" button. After a week or so that stopped but t would still crash occasionally - however - since the last crash (07/03/2020) and recovery I now get a "the identity of this website or the integrity of this connection cannot be verified" security squawk whenever I open or save a project
anzacinexile wrote:I now get a "the identity of this website or the integrity of this connection cannot be verified
I believe we are all getting that, well I am as well.
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Post by AbhijitR »
It seams the Security Certificate has expired on 08-03-2020, is it? I hope this will be fixed soon, still forum can be accessed, relief.
(16.07 KiB) Downloaded 1615 times
Post by Steve »
Hi all,
We upgraded the site's certificate a few weeks ago, but there seems to be a problem with it when it changed over today. We're looking into it and should rectify it in the next hour or so.
And I hope to have a new installer for Flowcode v8 out later today.
Steve.
Dirk Bubley
Has thanked: 14 times
Post by Dirk Bubley »
Frank607 wrote:Hi,
Frank
UPDATE:
Hello FC Team,
i have exactly the same Problem like Frank reported here already. I have WIN 10 too and FC8 Prof. Version.
After the crash it is fine just to delete the Reg Key.
Then FC 8 open.
Note!!! If the crash occurs you will be asked to save your FC Project bevor WIN10 will shut down. Don`t save your Project or you will loose the majority of you Marcros.
Hope there will be a fix soon.
By they way I have SCADA to. This is working after the shut down and not affected by the Problem.
BR
Dirk
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Post by viktor_au »
I had the same problem on 2nd April 2020.
Finally I understood that the problem is in the corrupted registry.
After I renamed the registry the FC8 has created a new one
and I have never had any problems.
Dirk Bubley
THX Victor,
I will check your solution.
I had the Problem already twice.
I deleted the Reg Key after the first case and installed FC8 again. This was running until yeserday.
Then i deleted yesterday only the Reg Key...
...until now FC8 is running again and there is a new Reg Key again.
As far as I remember the crash happend shortly I was playing with F2 and F3 Zoom Funktion.
Then I selected a decision Icon.....
BR
Dirk
Post by Steve »
Thanks for the info. Can you please ensure you're using the latest version of v8 (v8.2.2.15).
(33.67 KiB) Downloaded 1041 times
maharadga
Post by maharadga »
I see that have newer version of the my - 8.2.1.13
How can I update to the latest if option "Check for update" is no active?
Hi maharadga,
Steve's post from here
Steve wrote:I think that link for the patch just takes v8.0.x and v8.1.x versions to v8.2.0. This update is essentially a service pack.
To upgrade from v8.2.1 to v8.2.2 you will need the hotfix that is available via the second link in Ben's post.
Steve is referring to the main Flowcode download URL
Ben's post can be found just above it.
Dirk Bubley
Hello together,
I´m running now FC8 in Version 8.2.2.15 over 10 days and the Problem with the crash did not came back.
May it looks that the problem is fixed.
BR
Dirk
Post by Steve »
Thanks for letting us know, Dirk.
