How to set up 74HC595 in this circuit with the Flowcode?
like this
is it possible؟
Yes it's possible but you will need to make your own macros to toggle the pins in the correct way to output the codes you need specific to your hardware setup. Should be fairly straightforward.is it possible؟![]()
