74HC959 guidance
RABO2320
Has thanked: 1 time
Been thanked: 2 times
74HC959 guidance
Post by RABO2320 »
How to set up 74HC595 in this circuit with the Flowcode?
like this
is it possible؟ :?: :roll:
Has thanked: 1135 times
Been thanked: 299 times
Re: 74HC959 guidance
Post by jgu1 »
Hi RABO!
In FC8 Ben create a component for the display build up around the 75hc595 Work perfect(suppose it this chip you mean this is you mean).
have a look here:
viewtopic.php?f=78&t=21826&p=99637&hilit=74hc595#p99637
Hope this help :D
Br jorgen
RABO2320
Has thanked: 1 time
Post by RABO2320 »
Hi jorgen.
Thanks for the tips.
In the real world, a chip is needed to set up every 7 segments. :!:
Like the bottom circuit:
But I want to start the 4x7 segment with two chips. :?
HC595.fcfx
(9.14 KiB) Downloaded 264 times
7segment_CA02.rar
(29.87 KiB) Downloaded 238 times
is it possible؟ :?:
Yes it's possible but you will need to make your own macros to toggle the pins in the correct way to output the codes you need specific to your hardware setup. Should be fairly straightforward.
Let us know how you're getting on.
RABO2320
Has thanked: 1 time
Post by RABO2320 »
Thanks for the reply.
Unfortunately, I'm a beginner in Flowcode(Of course, the flowcode is amazing).
And I was only able to design the upper circuit.
please guide me
