Arduino PWM
mnf
Has thanked: 70 times
Been thanked: 440 times
Arduino PWM
Post by mnf »
This might be me - PWM doesn't seem to work on Arduino (I tested Nano)
Using Channel 6 (Pin D3) - PWM::Enable() and PWM::SetdutyCycle(200) - just gives no output on pin.
Using Arduino IDE and pinMode(3, OUTPUT); analogWrite(3, 200); - gives a very nice square wave with 78.4% duty cycle as expected..
Am I doing something wrong - I tried various PWM channels / combinations of speeds.
pwm 2.fcfx
(7.9 KiB) Downloaded 212 times
How it should look:
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Re: Arduino PWM
Post by jgu1 »
Hi Martin!
You deserve an answer. :wink: Maybe no help, but here my test.
When I test with your testprogram With cal., your rigth, no PWM out.
I made a test with the PWM component and it work. Maybe stupid question, why use the cal? I know it has something to do with creation component or simulation. I have no experience with this, probably a fault from me :lol:
Br Jorgen
PWM_Martin.fcfx
(7.32 KiB) Downloaded 233 times
mnf
Re: Arduino PWM
Post by mnf »
Hi Jorgen,
Many thanks for that - works perfectly... Why did I use CAL - I searched for the PWM component - and it was the first I found.
Had never used PWM before.... Should have used search rather than looking through the component lists....
jgu1
Re: Arduino PWM
Post by jgu1 »
Hi Martin!
Glad I was able to help you and maybe a little repay with a fraction for your always helping. :lol: :lol:
Br. Jorgen.
Re: Arduino PWM
Glad you've got it working. Sorry for the lack of a reply.
The PWM component uses the CAL component behind the scenes but also calls the ChangePeriod function as part of the Enable macro which is probably the bit you were missing from your CAL program.
