PIC18F47Q10 ADC not working
- Flowcode V4 User
- Has thanked: 29 times
- Been thanked: 30 times
Re: PIC18F47Q10 ADC not working
I have copied the file in into the the stated folder, re-started flowcode and even cleared the cache. I have tried multiple channels of the PWM, saved the program under a differnet version number, re-compiled but unfotuantly it still does not seem to be working.
Do you think maybe its got something to do with using the HFINTOSC @ 64Mhz? (I have also tried it @4Mhz but no change)
I'm running with the 64MHz INTOSC too so that shouldn't be causing any issues.
The attached should solve the ADC problems for you.
Simply copy the file here.
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC
I'll get both fixes pushed to the update system ASAP.
Should be available via the update system for you now.
- Flowcode V4 User
- Flowcode V4 User
I think I may have found another issue with the Q10... As soon as I add the EEPROM component onto the panel then try and compile I get the following compiling errors.
-w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_EEPROM.c:212:18: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_EEPROM.c:212:21: error: (182) illegal conversion between types
int -> volatile union S708
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_EEPROM.c:227:18: error: (255) not a member of the struct/union ""
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\PIC\PIC_CAL_EEPROM.c:227:21: error: (182) illegal conversion between types
(908) exit status = 1
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode v8\Flowcode Batch Files\XC8 v2.20.bat reported error code 1
Thanks for letting us know, hopefully should be fixed for you now.
- Flowcode V4 User
I have another "Qiurk" with the Q10...
I am running on the inteernal 64Mhz oscillator, and one some chips the ADC works fine, but on others I get some random values. I have managed to get around this issue on some of the ADC's by decreasing the conversion speed (to Fosc/64). This stabalises the values far more, but it still does not seems to be accurate (one chip will read the voltage differnetly to another one). Any idea's how I can fix this?
Secondly, on one of the ADC's I have a thermistor. I am having the same problems with the "random values" but as I am using the flowcode component, I can not slow the sample rate down like with a standard ADC. I would prefer to stay with the flowcode component as I like how it converts the ADC voltage to a temperature.
- Has thanked: 18 times
- Been thanked: 16 times
Hello?
I connected to RD4 to detect the limit switch. On/off is good in hardware. However, it does not work well with FC8. I will upload the program, so please check it. And the active high/low at the digital input output does not work clearly,
Thank you.
Thank you.
- Shoes_Case.fcfx
- (21.35 KiB) Downloaded 257 times
- Flowcode V4 User
Morning Ben
Is it possible you can look into my previous post with the ADC's and the thermistors? It is not a noise issue as all the ADC inputs (including thermistors) have a 0.1uF cap to GND near the ADC pins.
Thanks for the poke, I have updated the thermistor component with the ADC conversion speed and precharge delay so hopefully that should allow you to proceed. Let me know if you have more issues with the Q10 devices, there could be something extra we are currently not understanding in terms of the ADC peripherals.
I want to use the touchpad. But it doesn't work. It works well with programs created by others (MPLab X IDE).
However, it does not work in FC8, and only 0 is displayed.
Please help me.
Please help me.
Please can you attach your program so we can see what your doing.
Also are you running the latest version of v8 and with all the latest component updates?
I'm using final version. And update everyday.
Thank you
Thank you
- Level.fcfx
- (26.43 KiB) Downloaded 217 times
Aha ok adc should work ok but touch isn't currently implemented there should be a warning about this when you compile. I'll see if it's something we can add for you.
Very sorry for the delay, it should be there for you now for the Q10 devices.
