Hi guys,
Seems a small FC I2C Component defintion bug. In Flowcode for this MCU, there are 4 channels defined: 1, 2, 3 and 4.
> However... although this MCU (64 pin version) has got 4x I2C channels, which is correct, the MCU pinout for I2C channel 2 is not present on this chip.
> This MCU has got in fact Channels 1, 3, 4 and 5 active.
> I've included an extract of the Data Sheet Showing all channel pinouts.
> I've also included a screenshot of Flowcode's I2C channel definitions for reference.
Could you be so kind as to fix the I2C Clowcode Component definitions?
Many thanks in advance as always!
R
PIC32MZ1024EFF064 I2C Definition Problem
ronaldlijs
- Has thanked: 20 times
- Been thanked: 25 times
- i2c_fc8_component_pinout.jpg (65.41 KiB) Viewed 2232 times
- i2c_pic32mz1024eff964_pinout.jpg (79.16 KiB) Viewed 2232 times
ronaldlijs
Re: PIC32MZ1024EFF064 I2C Definition Problem
I've attached the FC Project File for reference and forgot to mention that it compiles without errors.
- PIC1_MAIN_LEFT_V1.fcfx
- (24.22 KiB) Downloaded 190 times
Thanks for letting us know. I have hopefully now fixed the problem and pushed the change to the update system.
ronaldlijs
Fantastic, thanks as always for the very prompt reply and in this case fix!
Cheers!!!
R
Cheers!!!
R
