Installing Flowcode Ver 8 on a new Laptop.
billduck
Has thanked: 23 times
Been thanked: 16 times
Post by billduck »
I had do do so because of hardware problems on an old laptop. So I need to know how to do so. I am running Flowcode, but my install does not know which components I have paid for. The message when I compile to chip is "AVR Toolchain is not installed. Visit http://flowcode.co.uk/flowcode to download".
Thanks in advance.
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Installing Flowcode Ver 8 on a new Laptop.
Post by mnf »
Hi Bill,
Have you installed the AVR tool chain?
See https://www.flowcode.co.uk/flowcode/download/
billduck
Post by billduck »
That appears to have worked. As usual, thank you Martin.
I am surrprized that on the newer laptop and operating system
that when I choose Build / Project options that the dialog is different
in terms of identifyong the port where the UNO resides. See the image attached.
Project options.png (186.15 KiB) Viewed 6084 times
GerhardB
Has thanked: 3 times
Flowcode v8 with toolchain error
Post by GerhardB »
I have also the problem with the toolchain error.
I use Flowcode v8.2.2.15 and the pic8 toolchain picv2 - does this match?
Flowcode and toolchain uninstalled via regedit all entries deleted.
Flowcode new installed without starting Flowcode then toolcain installed (with and without common directory)
... the same toolchain error occures.
Should be an entry by $(compilerpic)?
What can I do now?
Thankyou for help.
Gerhard
billduck
Post by billduck »
The above solution by Martin worked for me.
Hi Gerhard,
This is from my compiler options:
See if this post helps
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
The install for the v2 of the PIC8 toolchain was implemented to work for v9 of Flowcode. For v8, you should use the v1 of the toolchain. The download for this is available in the Flowcode v8 section of your account page (https://www.flowcode.co.uk/accounts/)
If you are comfortable with manipulating the Windows registry, you could potentially change some values to 'point' Flowcode v8 at the location of the v2 install (it is the "Compiler_pic" entry in HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\MatrixTSL\Flowcode\Common), but v8 was designed to use the v1 of the toolchain and so that is what is recommended.
GerhardB
Post by GerhardB »
thanks for the hardcopy with the compiler options.
It helps to compare.
Gerhard
GerhardB
Post by GerhardB »
Hi Steve,
thanks for your help.
It works with the PIC8 toolchain v1
Gerhard
