I had do do so because of hardware problems on an old laptop. So I need to know how to do so. I am running Flowcode, but my install does not know which components I have paid for. The message when I compile to chip is "AVR Toolchain is not installed. Visit http://flowcode.co.uk/flowcode to download".
Thanks in advance.
Installing Flowcode Ver 8 on a new Laptop.
mnf
- Has thanked: 70 times
- Been thanked: 440 times
Re: Installing Flowcode Ver 8 on a new Laptop.
Hi Bill,
Have you installed the AVR tool chain?
See https://www.flowcode.co.uk/flowcode/download/
billduck
- Has thanked: 23 times
- Been thanked: 16 times
That appears to have worked. As usual, thank you Martin.
I am surrprized that on the newer laptop and operating system
that when I choose Build / Project options that the dialog is different
in terms of identifyong the port where the UNO resides. See the image attached.
- Project options.png (186.15 KiB) Viewed 6097 times
GerhardB
- Has thanked: 3 times
Flowcode v8 with toolchain error
I have also the problem with the toolchain error.
I use Flowcode v8.2.2.15 and the pic8 toolchain picv2 - does this match?
Flowcode and toolchain uninstalled via regedit all entries deleted.
Flowcode new installed without starting Flowcode then toolcain installed (with and without common directory)
... the same toolchain error occures.
Should be an entry by $(compilerpic)? What can I do now?
Thankyou for help.
Gerhard
Thankyou for help.
Gerhard
Hi Gerhard,
This is from my compiler options: See if this post helps
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
The install for the v2 of the PIC8 toolchain was implemented to work for v9 of Flowcode. For v8, you should use the v1 of the toolchain. The download for this is available in the Flowcode v8 section of your account page (https://www.flowcode.co.uk/accounts/)
If you are comfortable with manipulating the Windows registry, you could potentially change some values to 'point' Flowcode v8 at the location of the v2 install (it is the "Compiler_pic" entry in HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\MatrixTSL\Flowcode\Common), but v8 was designed to use the v1 of the toolchain and so that is what is recommended.
GerhardB
Hi Martin,
thanks for the hardcopy with the compiler options.
It helps to compare.
Gerhard
Gerhard
GerhardB
Hi Steve,
thanks for your help.
It works with the PIC8 toolchain v1
Gerhard
Gerhard
