485 analog input register
MikeVerweij
Post by MikeVerweij »
My name is Mike and for a current project i am working with rs485 RTU on Flowcode 8.
I need to get an analog input working on the slave, i tried setanaloginput and read analog input, but i cant see the changes on my master.
I know how to get the digital in and outputs working but it does not work the same with the analog... I wonder if anyone can look at my code and tell me what i am doing wrong and how to get it working :D
Thanks in advance.
Forum analoog vraag.fcfx
(15.59 KiB) Downloaded 244 times
dannyvanneijenhoff
Has thanked: 17 times
Been thanked: 10 times
Re: 485 analog input register
Post by dannyvanneijenhoff »
bump :D
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Post by viktor_au »
Hello Mike
When Modbus master sends a request to slave what is the value of byte 'raw_RX_antw_master'?
Can you insert in your code the decision:
If raw_RX_antw_master=255
Is it CRC issue?
Did you try to send to Modbus master only one analog value?
MikeVerweij
hi, thanks for a reply.
I tried it but it is not a CRC fail, the slave will answer a default replay as it seems from the scope.
It doesn't matter what i set the answer will always be the same(see attachments), even if i remove everything and only initialise the slave.
I wonder if you can take a look at this and tell me what the problem is because i can't see it.
Kind regards, :D
forum question analog input.fcfx
(19.28 KiB) Downloaded 226 times
anwser slave.png (28.11 KiB) Viewed 3211 times
viktor_au
Post by viktor_au »
Hello Mike
I changed a bit your Slave12 and run it with FC8 run Master (not on PIC, bur Arduino).
All works OK on Arduino.
Please check you PIC hardware connections and settings.
I created a quick guide.
https://www.flowcode.co.uk/mmforums/view ... 60#p103660
