STM 32Nucleo
jgu1
Has thanked: 1135 times
Been thanked: 299 times
STM 32Nucleo
Post by jgu1 »
Hi!
After a while I want to continue with a project. When I opened the project and want to complile without done anything, I now get ERROR 1 ?
I try create a new project with only a loop in the program I get the same error?
Att. my testprogram.
I think it is after last update with Arm devices. If I am wrong or do something wrong, sorry :D
Br Jorgen
KruuseTest.fcfx
(27.68 KiB) Downloaded 376 times
Nytest.fcfx
(8.36 KiB) Downloaded 335 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: STM 32Nucleo
Post by LeighM »
Could you try dropping the attached file into
C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\ARM
32F410Nucleo64.fcdx
(24.86 KiB) Downloaded 352 times
jgu1
Re: STM 32Nucleo
Post by jgu1 »
Hi Leigh!
Yes, now I can program the chip again, but now there is something wrong with the orientation. If I set it for one or more, some strange sign/tekst.
The display background and foreground ok?
Br Jorgen
LeighM
Re: STM 32Nucleo
Post by LeighM »
Problems with the ILI9341 gLCD?
Can you give more details? Perhaps a photo?
Can you check your SPI settings?
jgu1
Re: STM 32Nucleo
Post by jgu1 »
Yes the ILI9341.
I am sure that the connection is ok. It has worked and I have change the wire. If not correct, I don`t Think I was able to change
backgroundcolour or foreground.
I remember for some month`s ago, there also was an Update for this display. So could be a bug in this update.
jgu1
Re: STM 32Nucleo
Post by jgu1 »
    As soon I set the orientation zero it`s ok! But not this direction I wan`t :roll:
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Hey MM!
    Please, disaster disaster. First I start on a project, it seem to work, then came an update for my device, then is it not possible to program my device :(
    After loooong time battle and I inform the bug a new update come, then I use the corrected file and is again able to program again :D But now my display behavior strange. Again after looong time battle and troubleshooting I see that a new bug is coming after an update of this too :( If I I use orientation 1 or higher, see picture above.
    for the display I try to go back in update, but again...
    And now I can program, but suddenly my display not work at all, Please please MM team, I use so much time on bugs I think I always try to be helpfull if I can, and I know FC is a big program, but now I am beginning to be confused.
    Most of the time, when I have start a project, I said "Yes" and keep my hand up and it work and I am happy. But everytime I see there are lot of correction, I think, hopefully all still work.
    Hopefully, if I buy, Flowcode 9 when it release, that we not have to start from beginning with lot of bugs as we have done in all the earlier version.
    Regard from a little crying confused man who always have used and loved Flowcode, but....
    Jorgen
    LeighM
    Re: STM 32Nucleo
    Post by LeighM »
    Hi Jorgen,
    If a previous version of the gLCD component worked OK for you,
    could you try rolling back to that version via the update system?
    let us know how that goes and it will help us to track down the issue ...
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Hi Leigh!
    Thank´s for reply. I already have done your suggest, but then, When I discover that the orientaion not working after last last update of Ili9341 component:
    Then I try to go back in version. After that the display not work at all, well then I try an update again and there was of course update available, run this, but it still not work at all.
    So, the hard knife :lol: uninstall FC8 and reinstall again, help, update, but the display still not work after programming :(
    I have FC8 on a another PC. try to use your update file for for the Nucleo, the display work, but not the orientation. So now I have two issue.
    Pc one display not work at all, no matter what I do, What have I done wrorg here?
    Pc 2 display work but cannot use rotation in the component (bug in the component after last update).
    Hope it make sense Leigh, despite my bad english.
    Look fprward to her from you.
    Jorgen
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Edit:
    don´t know what. Suddently there is life in the display again after programming, testet on both PC, could it be after restart of pc? Nice!
    But still bug in the orientation of componentmacro, is it possible to fix this? I dare not to switch back in earlyer version.
    And I see the Nucleo FCDX file not is push in the update, Is it something you will do, Please? :D
    If it is possible to fix these two thing this will make happy again and I can continue my project :wink:
    Jorgen
    LeighM
    Re: STM 32Nucleo
    Post by LeighM »
    Hi Jorgen,
    Thanks for your update.
    Could you please try just printing something simple on the display, such as "1234567".
    then take a photo in orientation 0 and 1
    (I don't have one of these displays)
    Hopefully we will get the FCDX changes to the auto-update system soon.
    Leigh
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Hi Leigh Sorry have to upload 3 times
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Orient0: Seem to be ok!
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Orient 1 Not ok. Deleting is also not working when use orient 1
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Orient 2 look like mirror looking in mirror :lol:
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Orient 3 also like mirror.
    As you see, something wrong. Hope it help and make sense. And again this occour after last update of this display. Earlyer it was ok.
    Leigh_test.fcfx
    (12.53 KiB) Downloaded 353 times
    Alkaline
    Has thanked: 42 times
    Been thanked: 41 times
    Re: STM 32Nucleo
    Post by Alkaline »
    I also use an ili9341 and the problem I encounter with versions 13-14 while the 12 works correctly.
    I also use a stm32 mcu. However, the connection is parallel 8 bits
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Thank´s Alkaline for info, mine is serial. Hopefully MM guy´s soon fix it :wink:
    Jorgen
    Re: STM 32Nucleo
    Hopfully fixed for you now :D
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Hi Ben!
    Thank you. a Little better no mirror any more, but something is wrong with X and Y it is not moving the text always. When I simulate it is ok. but not
    in real world :(
    KruuseTest.fcfx
    (27.5 KiB) Downloaded 246 times
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Hi again!
    I have now tested further. it is also not possible to make rectangular and then fill the color with a foreground color.
    Then I try to go back in version. I have to go back to ver. 10 for the Ili9143 komponent before it seem begining to work correctly?
    Jorgen
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Hi Ben!
    Now I have made a lot of test with the v.10 Ili943 component, and it semed to be ok I don´t know what the difference is from V.10 to V.15, but is there nothing concerning the X and Y cordinates you can use in v.15 from v.10?
    Br jorgen
    jgu1
    Re: STM 32Nucleo
    Post by jgu1 »
    Hi MM team!
    Kindly, something new? :wink:
    Br Jorgen
    Re: STM 32Nucleo
    Thanks for letting us know.
    I've had another pass through and hopefully solved the problems, let me know how you get on and if everythings ok then I'll push the changes through to v9.
