Hi guys,
Trust everyone is OK and safe these days.
Does FC8 support a 96x32 pixel OLED display with SSD1316 controller? Would I not be able to use the SSD1306 I2C component and adapt it in some way?
Thanks for your thoughts!
R
96x32 OLED SSD1316 I2C Supported?
- Has thanked: 20 times
- Been thanked: 25 times
- Has thanked: 70 times
- Been thanked: 440 times
Re: 96x32 OLED SSD1316 I2C Supported?
If you send me one of the displays I'll have a go....
Just been doing a st7789 (spi) display - which works (at least on some displays
The source for the ssd1306 has been published and it shouldn't be too hard to modify for the different resolution..
Devi solo cambiare il numero dei pixel da standard a 96 x 32 dal pannello properties.
Io ho provato cambiando la risoluzione standard a 128 x 32 e basta stampare i caratteri calcolando i pixel scritti.
Comunque il componente SSD 1306 I2C funziona correttamente anche con setting di risoluzione diversi ( nel mio caso 128 x 32 )...
Saluti e ovviamente
traduce with google traslator.
Solozerouno.
Saluti e ovviamente
Solozerouno.
