96x32 OLED SSD1316 I2C Supported?
ronaldlijs
Has thanked: 20 times
Been thanked: 25 times
Post by ronaldlijs »
Hi guys,
Trust everyone is OK and safe these days.
Does FC8 support a 96x32 pixel OLED display with SSD1316 controller? Would I not be able to use the SSD1306 I2C component and adapt it in some way?
Thanks for your thoughts!
R
ronaldlijs
Re: 96x32 OLED SSD1316 I2C Supported?
Hi all,
No-one can help?
Thanks,
R
mnf
Has thanked: 70 times
Been thanked: 440 times
Post by mnf »
If you send me one of the displays I'll have a go....
Just been doing a st7789 (spi) display - which works (at least on some displays :? )
The source for the ssd1306 has been published and it shouldn't be too hard to modify for the different resolution..
Solozerouno
Post by Solozerouno »
Devi solo cambiare il numero dei pixel da standard a 96 x 32 dal pannello properties.
Io ho provato cambiando la risoluzione standard a 128 x 32 e basta stampare i caratteri calcolando i pixel scritti.
Comunque il componente SSD 1306 I2C funziona correttamente anche con setting di risoluzione diversi ( nel mio caso 128 x 32 )...
Saluti e ovviamente
traduce with google traslator.
Solozerouno.
