Ghost Issue with 16F648A
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Post by QMESAR »
Hi Team.
I am having issue with a PIC16F648A and Ghost ,
It is inpossible to add a Analog trace to the Data Recorder
Here you can see pins RA2 and RA 3 are set as Analog pins in Ghost this is done automatically by FC
Gosht Select.jpg (15.37 KiB) Viewed 1871 times
Trying to select the RA2 or RA3 as Analog pin in the recorder is not possible the Analog pin selection is always grayed out
Trying to add a Data recorder Component to the 2D panel and select the pins in the property window all pins not available for selection.
Can you guys help out this is a urgent project please I cannot debug with Ghost at the moment
Appreciate all help
Re: Ghost Issue with 16F648A
Here's a definition file that should solve the problem for A2 and A3. As there is no ADC peripheral on the device we haven't enabled it for any of the pins.
16F648A.fcdx
(14.06 KiB) Downloaded 158 times
Needs to be copied here.
C:\ProgramData\MatrixTSL\FlowcodeV8\FCD\PIC
I won't do an official release for this one as it might throw a user who wants ADC functionality.
QMESAR
Post by QMESAR »
[Hi Ben
Thank you very much :D
