MIAC 8BIT
franky1978
MIAC 8BIT
Post by franky1978 »
hi at all,
i have a flowcode v8 licence but i also have a miac 8 bit whit his licence, how can i use the last one in flowcode v8?
thanks
Has thanked: 114 times
Been thanked: 422 times
Re: MIAC 8BIT
Post by Steve »
To start, select "New Project...Embedded" and choose the "MIAC V2" in the "8-bit PIC" section (the same target can also be found under "Free targets").
If you add the "MIAC (PIC)" component to your project, you will then have access to MIAC macros. This can be found under "Hardware...MIAC Module".
Alternatively, there is a template project for the MIAC with the component pre-loaded. This is under "Open Template...Chips...Other".
franky1978
Re: MIAC 8BIT
hi Steve,
i have tried but when try to download the project to miac i have this error
"pic compiler toolchain is not installed"
Re: MIAC 8BIT
Post by Steve »
If you log in here with your Matrix account details (note: this is not this forum login, but is the same login as the v9 forum), you can access the toolchain downloads:
https://www.flowcode.co.uk/accounts/login/
For the MIAC, you will need the PIC 8bit Toolchain:
franky1978
Re: MIAC 8BIT
i have solved thanks!
