ADC internal Vref Activate
RABO2320
Has thanked: 1 time
Been thanked: 2 times
Post by RABO2320 »
please guide me
in the FC v8
I want to enable the internal reference voltage for ADC but there is no such option in ADC properties.
I even referred to the AVR_CAL_ADC.c file and:
changed the REFS1 & REFS0 bit in the ADMUX registry but it didn't work. :!: :!: :?: :!: :!:
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: ADC internal Vref Activate
Post by LeighM »
What device are you using?
RABO2320
Has thanked: 1 time
Post by RABO2320 »
I used AVR ATMEGA 8A.
RABO2320
Has thanked: 1 time
Post by RABO2320 »
Please someone guide me
How to enable internal reference voltage( int.Vref ) for ADC in FlowCode V8. :?: :?: :?: :?: :?:
I am using AVR microcontroller.(ATMEGA8)
Has thanked: 187 times
Been thanked: 205 times
Post by chipfryer27 »
Can you be a bit more specific? Do you mean the AD7680 component or the generic Potentiometers? If the latter it's very simple under Properties.
Edit....
Posted before finishing my sentence (Doh..) If AD7680 then as far as I'm aware it only uses the Power Supply as reference
RABO2320
Has thanked: 1 time
Post by RABO2320 »
No, I do not use the AD7680 component.
I am using one of the ADC microcontroller input pins.
I input a sampled voltage to the ADC microcontroller input pins.This voltage is between zero and five volts.
I want to use 2.56 volts is the internal reference voltage for the ADC reference voltage.
Hi RABO2320
Can you paste tthe following within windows explorer:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\AVR
Then replace the existing file with the attached version.
You will need to reload the flowchart after.
The file is untested as I have not got the same target device to test on.
You will need to change the reference properties to Vref +pin.
Instead of Vref +pin, hopefully it will work with 2.56 internal reference?
AVR_CAL_ADC.c
(26.77 KiB) Downloaded 337 times
RABO2320
Has thanked: 1 time
Post by RABO2320 »
The file you ATTACHMENTS does not work properly and gives the following error in the simulation:
Sorry, It was a typo.
Can you try the attached and see if it works?
AVR_CAL_ADC.c
(26.77 KiB) Downloaded 323 times
RABO2320
Has thanked: 1 time
Post by RABO2320 »
Thank you for your guidance.
This file worked perfectly.
That's excellent.
Thanks for letting me know.
