DSP_Test
r_teixeir
Has thanked: 24 times
Been thanked: 5 times
DSP_Test
Post by r_teixeir »
Hi Team, Iam trying to get my hands on the DSP components and the DAC_Output MCP4901. Please I Need help on code considering that amount errors on the compiler message.
Thanks I appreciate
Rod
DSP_Teste1.msg.txt
(10.53 KiB) Downloaded 167 times
DSP_Teste1.fcfx
(17.98 KiB) Downloaded 152 times
Re: DSP_Test
I've just tried your project using FC 8 and it's all compiling correctly for me. It might be worth you going to Help -> Check for updates and changing Files in Use to Full Database to do a full update. Fingers crossed once you've done this your project will compile as expected.
Let us know how you get on.
nnnnff
Has thanked: 3 times
Been thanked: 6 times
Re: DSP_Test
Post by nnnnff »
r_teixeir
Re: DSP_Test
Post by r_teixeir »
Hi guys it is compiling correct. Ben was right I had to do an update.
Rod
