Hi Team, Iam trying to get my hands on the DSP components and the DAC_Output MCP4901. Please I Need help on code considering that amount errors on the compiler message.
Thanks I appreciate
Rod
DSP_Test
DSP_Test
- DSP_Teste1.msg.txt
- (10.53 KiB) Downloaded 195 times
- DSP_Teste1.fcfx
- (17.98 KiB) Downloaded 181 times
Re: DSP_Test
I've just tried your project using FC 8 and it's all compiling correctly for me. It might be worth you going to Help -> Check for updates and changing Files in Use to Full Database to do a full update. Fingers crossed once you've done this your project will compile as expected.
Let us know how you get on.
