ssd1306 Shows symbols instead numbers
dds.m.blal
Post by dds.m.blal »
Hi everyone. I have a 128x32 glcd_ssd1306_i2c and an Arduino Nano and I couldn't get any numbers to show on it. All that shows are symbols only.
Flowcode1.fcfx
(9.15 KiB) Downloaded 51 times
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Re: ssd1306 Shows symbols instead numbers
Post by viktor_au »
Can you please give more information?
Did you try a second, third OLED?
Do they all work the same?
Does Nano work OK with 1 second B5 flash?
dds.m.blal
I moved to Flowcode version 6 and the same lcd and nano board work perfectly.
viktor_au
Post by viktor_au »
I used the FC8.
Works OK, only one problem with 'interlaced' function.
Didn't work in 'yes' version.
No problems with 100kHz or 400kHz
viktor_au
Post by viktor_au »
Can you please share the results?
What was the problem?
