Russian inscriptions.
- NOPROBLEM48
I congratulate all happy New Year!
I have noticed, that if to write in Russian in display name in a window properties for blocks of a cycle and decision at compilation the error appears. And other blocks in this case are absolutely excluded from compilation without preventions.
And should be, or I that incorrectly do?
Thanks for technical support!
NOPROBLEM
NOPROBLEM
- NOPROBLEM48
- NOPROBLEM48
Re: Russian inscriptions.
Greetings!
In archive two folders which differ only language on which shown names of blocks are written down!
Only I do not understand, how I can attach archive with examples to the message! Prompt, please!
- NOPROBLEM48
Thanks! At once has not seen! Here archive.
- RUSIK.ZIP
- Here archive.
- (30.29 KiB) Downloaded 509 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
I know what the problem is and you will need a new version of the Flowcode exe.
Luckily, I am working on an update at the moment and it should be ready later today.
- Steve
Please download and install the following patch, which should correct the problem:
http://www.matrixmultimedia.com/softwar ... v3.6.9.msp
Please let me know if it works ok.
- NOPROBLEM48
Thanks, Steve! Patch has allowed to form HEX with any headings. But already in a file in language C Russian letters in headings are replaced with signs?. While their names could be useful!
Thanks for the help.
- Steve
Unfortunately, there is no way around this. The C compiler cannot cope with non-standard characters in the C file.
By the way, the patch I gave you has a simulation bug in it. We will be putting up a new download shortly.
- NOPROBLEM48
It agree! Obviously, it is too serious problem to solve it some minutes! Once again thanks!
