Russian inscriptions.
Forum for problems or queries regarding the Flowcode application and compiler usage.
NOPROBLEM48
Post by NOPROBLEM48 »
I congratulate all happy New Year!
I have noticed, that if to write in Russian in display name in a window properties for blocks of a cycle and decision at compilation the error appears. And other blocks in this case are absolutely excluded from compilation without preventions.
And should be, or I that incorrectly do?
Thanks for technical support!
NOPROBLEM
Re: Russian inscriptions.
Are you using the latest version of Flowcode??
NOPROBLEM48
Yes! V 3.4.7.48 Professional Version.
Please send me a program that has this problem and I'll see if I can solve it.
NOPROBLEM48
Greetings!
In archive two folders which differ only language on which shown names of blocks are written down! :roll:
:oops: Only I do not understand, how I can attach archive with examples to the message! Prompt, please!
When editing a message, just below where you type is a tab "upload attachment". You need to "browse..." for the file and then click the "add the file" button.
NOPROBLEM48
Thanks! At once has not seen! Here archive.
RUSIK.ZIP
Here archive.
(30.29 KiB) Downloaded 651 times
I know what the problem is and you will need a new version of the Flowcode exe.
Luckily, I am working on an update at the moment and it should be ready later today.
Please download and install the following patch, which should correct the problem:
http://www.matrixmultimedia.com/softwar ... v3.6.9.msp
Please let me know if it works ok.
The above patch has now been removed. I still don't know if this has fixed your problem - can you please let me know.
NOPROBLEM48
Thanks, Steve! Patch has allowed to form HEX with any headings. But already in a file in language C Russian letters in headings are replaced with signs?. While their names could be useful!
Thanks for the help.
Unfortunately, there is no way around this. The C compiler cannot cope with non-standard characters in the C file.
By the way, the patch I gave you has a simulation bug in it. We will be putting up a new download shortly.
NOPROBLEM48
It agree! Obviously, it is too serious problem to solve it some minutes! Once again thanks!
