Flowcode V4
Henk
Flowcode V4
Post by Henk »
Hello there,
I have just download Flowcode V4.
Now the program aks for a key.
I have a key but when i fill in than de program says the key is not valid.
Can you tell me what the problem is.
I use the license for Flowcode V3.
Henk.
raptoru
Re: Flowcode V4
Post by raptoru »
You must buy a Flowcode 4 licence ... 50% discont if you have a V3 license.
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Re: Flowcode V4
Post by saschech@gmx.de »
Hallo
Question,question,question.......
Where i can open the component connections editor?
Elektor german dont no over v4.......
Is there a way for a 30 day key?
Can i buy direct?
Regards wolfgang
Has thanked: 114 times
Been thanked: 422 times
Re: Flowcode V4
Post by Steve »
Hi Wolfgang,
Component connections are in the properties frame, just under "extended properties" and above "customize code".
It's probably best to buy the upgrade from Elektor (if you came direct to us, they would accuse us of stealing their customer and we don't want this - Elektor are a good dealer for us).
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Steve
I find it,but where i can open it (connect to 2 ports) !
The virtual network works in the Demo?
What time elektor can provide the update my v3pro to v4 pro?
Regards wolfgang
Re: Flowcode V4
Post by Steve »
Click on the 3 dots next to "Connections".
Virtual Networks will be ready in 2 months, as will a full German version.
We don't have the CDs just yet - there was a printing issue that has held up our delivery. So I think Elektor can take orders but will not be able to ship a CD for a week or two.
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Steve
1) If i put the komponent-bar from the top on the left side,after a new start the bar is again on the top??
2) Where i can komponents out of the komponent-bar ?
V4 give mi a good impression!
Regards wolfgang
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Steve
I want compile a demo and become :
NICHT FÜR KOMMERZiELLE ANWENDUNGEN
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "1. Displaying a number.c"
Return code = 1
FINISHED
With my own project , i have the same error.
In the compiler-setting-help all parameter for V3:
Compiler location
Sets the Compiler location.
Default:
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe
Compiler parameters
Adds command line parameters when called from Flowcode
Default:
-v -t PIC%p "%f.c"
Linker/Assembler location
Sets the Assembler program location.
Default:
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostlink.pic.exe
Linker/Assembler parameters
Default:
-ld "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\lib" libc.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
Programmer location
Sets the Programmer application location.
Default:
C:\Program Files\Matrix Multimedia\Common\PPPv3\PPPv3.exe
To use the PICkit2 programmer change the location to
C:\Program Files\Matrix Multimedia\Flowcode V3\tools\PICkit2\pk2cmd_mtx.exe
Regard wolfgang
Re: Flowcode V4
Post by Steve »
We'll try to fix the component-bar issue in v4.1
And I'll ask Ben to try to help with the compilation problem.
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Steve
In the morning i install v4 on my virtual-PC running xp,compiling works ok.
I delete v4 on my pc,running Vista-bussines with all updates,turn off the UAC ,
install v4 as admin new,it come the compiling error again.
Regards Wolfgang
Re: Flowcode V4
Hello Wolfgang
I think your compilation problem is due to the way Vista can disable 8.3 filename generation.
We have a FAQ that details a way of resolving the problem available from here.
http://www.matrixmultimedia.com/support ... .php?t=550
Let me know how you get on.
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Benj
after i use fsutil... show the follow
Vista:
Return code = 0
FINISHED
no more
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
virtual vm-ware XP:
File name: C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment\1. Displaying a number.c
Generated by: Flowcode v4.0.0.53
Date: Wednesday, June 10, 2009 12:22:29
Licence: Demo
***DEMO VERSION***
NOT FOR COMMERCIAL USE
C:\Programme\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "1. Displaying a number.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Single user Lite License (Unregistered) for 0 node(s)
Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
Starting preprocessor: "C:\Programme\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" "C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment\1. Displaying a number.c" -i "C:\Programme\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC16F88 -la -c2 -o "C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment\1. Displaying a number.pp" -v -d _BOOSTC -d _PIC16
1. Displaying a number.c success
success
Return code = 0
C:\Programme\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Programme\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "1. Displaying a number.obj" -t PIC16F88 -d "C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment" -p "1. Displaying a number"
BoostLink Optimizing Linker Version 6.95
Warning unreferenced functions removed:
FCI_FLOAT_TO_STRING in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_INT in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_msDelay in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_S in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_Ms in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
isinf in: C:\Programme\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCM_INTERRUPT_TMR0 in: C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment\1. Displaying a number.c
FCM_INTERRUPT_RB0INT in: C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment\1. Displaying a number.c
FCM_INTERRUPT_PORTB in: C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment\1. Displaying a number.c
FCD_LED7Seg10_ClearDigit in: C:\Dokumente und Einstellungen\Administrator\Desktop\Examples\Components\7 Segment\1. Displaying a number.c
Building CASM file
Memory Usage Report
RAM available:368 bytes, used:47 bytes (12.8%), free:321 bytes (87.2%),
Heap size:129 bytes, Heap max single alloc:94 bytes
ROM available:4096 words, used:153 words (3.8%), free:3943 words (96.2%)
success
Return code = 0
FINISHED
after fsutil:
Aaministrator: vvinaows,system,cma.-
C:\Program Files>dir /x matrx
Datenträger in Laufwerk C: ist Uista Uolumeseriennummer: 9046-FAD2
Uerzeichnis uon C:\Program Files
10.06.2009 13:15 <DIR> MATRIX-1 Matrix Multimedia
0 Datei(en), 0 Bytes
1 Uerzeichnis(se), 18.218.291.200 Bytes frei
C:\Program Files>cd matrix-1
C:\Program Files\MATRIX-1>dir /x flowx
Uerzeichnis uon C:\Program Files\MATRIX-1
04.06.2009 12:51 <DIR> Flowcode U3
09.06.2009 00:00 <DIR> FLOWCO-1 Flowcode U4
2 Uerzeichnis(se), 18.218.094.592 Bytes frei
C:\Pro.ram Files\MATRIX-1>
ITISVARESE
Has thanked: 9 times
Been thanked: 3 times
Re: Flowcode V4
Post by ITISVARESE »
Same problem of compiling in Vista SP2: no hex file and i have key for full version today.
In XP with SP3 no problem work ok !
Not solved with previous post.
What i can do?
Thanks in advance.
Re: Flowcode V4
Have you tried the fix documented here?
I am running Vista 64 and Flowcode v4 is working 100% fine with the above mentioned fix.
We have also tested using Vista running in a VMware virtual environment and this has also been working well.
ITISVARESE
Re: Flowcode V4
Yes i tried it and not work on Vista SP2 32;
not have error but no compile like previuos user says in this discussion....
Maybe problem that i have before V4 flowcode V3?
Here result:
Microsoft Windows [Versione 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. Tutti i diritti riservati.
C:\Users\Io>cd c:\Program files
c:\Program Files>dir /x matr*
Il volume nell'unitΓ  C Γ¨ HP
Numero di serie del volume: 9A97-CDA8
Directory di c:\Program Files
10/06/2009 22.20 <DIR> MATRIX~1 Matrix Multimedia
0 File 0 byte
1 Directory 234.911.272.960 byte disponibili
c:\Program Files>cd Matrix Multimedia
c:\Program Files\Matrix Multimedia>dir /x flow*
Directory di c:\Program Files\Matrix Multimedia
10/06/2009 22.20 <DIR> FLOWCO~1 Flowcode V4
0 File 0 byte
1 Directory 234.911.240.192 byte disponibili
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo
To different installation with the thame error....
I think it is not a mistake of the pc
Regards wolfgang
Re: Flowcode V4
Hello Itisvarse
Have you done the 8.3 conversion for the Programs Files folder too?
Flowcode V4 works fine with V3 also installed. Also tested on Vista and no problems.
Hi Wolfgang
Sorry but I think the problem is PC related.
Please could you both try the following.
Start -> Run -> cmd
Then in the command prompt please type the following
cd c:\
dir /x prog*
You should get the following: <DIR> PROGRA~1 Program Files
If you get this then please type
cd prog*
dir /x matr*
You should get the following: <DIR> MATRIX~1 Matrix Multimedia
cd matr*
dir /x flow*
<DIR> FLOWCO~1 Flowcode V3
<DIR> FLOWCO~2 Flowcode V4
As long as the Flowcode V4 8.3 filename is present then your compilations should be working correctly.
If all the 8.3 filenames are present then there must be something else causing compilation to fail.
Please let me know how you get on.
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Benj
I have do thes with fsutil vor V4.After thes only the error 1 goto error 0 after i use fsutil yesterday.
V3 works perfect without short name.
dir /x matr* > text.txt,the result schow.
Datentr„ger in Laufwerk C: ist Vista
Volumeseriennummer: 9046-FAD2
Verzeichnis von C:\Program Files
10.06.2009 13:15 <DIR> MATRIX~1 Matrix Multimedia
1 Verzeichnis(se), 17.338.806.272 Bytes frei
Verzeichnis von C:\Program Files\Matrix Multimedia
04.06.2009 12:51 <DIR> Flowcode V3
09.06.2009 00:00 <DIR> FLOWCO~1 Flowcode V4
2 Verzeichnis(se), 17.340.309.504 Bytes frei
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Benj
Verzeichnis von C:\
11.06.2009 16:58 <DIR> PROGRA~1 Program Files
1 Verzeichnis(se), 17.339.305.984 Bytes frei
ITISVARESE
Re: Flowcode V4
Hello Benj,
I have made all You tell me; here is what You need but V4 don't compile ok,
and Flowcode V3, installed before V4, work ok.
Other error when i try to update or online resource in menu of flowcode i receive
" Sorry your key not recognized " and of course my key is original......
C:\Users\Io>cd..
C:\Users>cd..
C:\>dir /x prog*
Directory di C:\
10/06/2009 22.11 <DIR> PROGRA~1 Program Files
0 File 0 byte
1 Directory 235.031.461.888 byte disponibili
C:\>cd prog*
C:\Program Files>dir /x matr*
Directory di C:\Program Files
0 File 0 byte
1 Directory 235.031.437.312 byte disponibili
C:\Program Files>cd matr*
C:\Program Files\Matrix Multimedia>dir /x flow*
Directory di C:\Program Files\Matrix Multimedia
0 File 0 byte
Re: Flowcode V4
I have exactly same problem of V4 not compiling to hex.
I have checked and long file names is active for V4.
Operating system is windows vista home premium
I am trying to compile DC PWM 16F877A found in V4 examples.
For some reason, boost c complier is not activated.
Here is a screen shot.
V4 no hex.jpg (42.96 KiB) Viewed 20532 times
Re: Flowcode V4
Are any programs compiling or are they all failing to produce any hex files etc.
You could try moving your program to a directory just off the root to see if this helps the problem
Eg. C:\Progs\
If this doesnt help then another thing you could try is to install Flowcode into a folder off the root directory.
Eg C:\FC3 or c:\FC4
These tests will eliminate the path technicality which will hopefully help to get to the bottom of this problem.
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Benj
I have install a new vista bussines > v4 works well with compiler.
Steep by steep i install my software with test flowcode.
After i install "PS Tray Factory " v4 works and show:
File name: D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.c
Date: Friday, June 12, 2009 15:35:09
Licence: Demo
***DEMO VERSION***
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" "D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.c" -i "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC16F88 -la -c2 -o "D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.pp" -v -d _BOOSTC -d _PIC16
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "1. Displaying a number.obj" -t PIC16F88 -d "D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment" -p "1. Displaying a number"
FCI_FLOAT_TO_STRING in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_INT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_msDelay in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_S in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_Ms in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
isinf in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCM_INTERRUPT_TMR0 in: D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.c
FCM_INTERRUPT_RB0INT in: D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.c
FCM_INTERRUPT_PORTB in: D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.c
FCD_LED7Seg10_ClearDigit in: D:\sachs_work\Flowcode_V4_Examples\Flowcode_V4_Examples\Examples\Components\7 Segment\1. Displaying a number.c
Building CASM file
Memory Usage Report
success
Return code = 0
FINISHED
> after i start the "PS Tray Factory " v4 show:
Date: Friday, June 12, 2009 15:33:53
Licence: Demo
***DEMO VERSION***
Return code = 0
FINISHED
????? Regards Wolfgang
saschech@gmx.de
Has thanked: 1 time
Re: Flowcode V4
Hallo Benj
These effekt is replicable with start ..stopp ... the program
Regards wolfgang
ITISVARESE
Re: Flowcode V4
Hello Benj,
all last Your solution (V4 in other directory) don't work....
This is a big problem for Vista users.
