Int to Float
Eric
Been thanked: 1 time
Int to Float
Post by Eric »
What is the correct way to convert an Int to Float in V4?
I tried a test with this program:
It simulates but it won't compile, giving this error:
Searching the forum didn't clarified this. What went wrong?
Eric
Re: Int to Float
Hello Eric
Using BoostC this is a little awkward.
You can do the following.
Using a C code icon and the flowcode variables fl_var and int_var.
FCV_FL_VAR = float32_to_int32(FCV_INT_VAR);
There are further functions available inside the calculation icon which can be used to do floating point calculations in BoostC. These functions will work inside the calculation icon.
Hope this helps.
Eric
Re: Int to Float
Post by Eric »
Not really, I still have errors.
Can you please verify or complete this test program so that this program works?
Test1.fcf
(5 KiB) Downloaded 371 times
Thx,
Eric
Has thanked: 114 times
Been thanked: 422 times
Re: Int to Float
Post by Steve »
Please try float32_from_int32 instead.
We will add these conversion routines into Flowcode itself so you do not need to resort to C code.
Eric
Re: Int to Float
Post by Eric »
Good idea, because float32_from_int32 also gives similar errors.
Eric
Eric
Re: Int to Float
Post by Eric »
And please don't wait until V5.
Send us an Flowcode 4.1 update :-)
Rgds,
Eric
Re: Int to Float
Hello Eric
Here is a working version of your program.
Test1.fcf
(5 KiB) Downloaded 355 times
Eric
Re: Int to Float
Post by Eric »
Thx Ben, now I see.
But the compiled program is hugh !
7.5K !
Floating point seems to consume a lot of resources.
Rgds,
Eric
