I have a 18F6527 and I use the two UART. I would like to use the two uart in interrupt mode.
With only one, it works very well ( I juste have to add "set_bit(intcon, PEIE);" at the top of my program ).
I made some modification on the FCD file to add the second interrupt but if I use the two of them in my program, neither works
I attached my FCD file if somebody can have a look.
Thank you for your help !
